Hey forum,
looking for some assistance - I’m attempting to re-assign a sequential order to a linear array of curves. Attached is the reference. On the left is the current order, On the right in green the desired sequence - thin I’m suffering a case of Friday-brain.
Of course it’s possible! An abbreviated file would be preferred anyway, not interested in proprietary secrets. Which way is up/down on that image? If Z then sort the start points by their Z value and wire the curves to the second input of Sort.
Where did you get your image? That’s not the one he posted. There wasn’t enough information to answer this question without making (and explaining) assumptions.
you are right, what I meant was "because I can see a plane in the background of your lines, then you can for sure use one of those axis as reference for sorting the points: for instance, if the axis shown was Z like in my picture, then Z could be used for that purpose "
in general, assuming the starting points of your curve are somehow aligned, you can always use sort points along curve with a curve built just ad-hoc for that purpose, in such a way you are not axis dependant anymore
