I have multiple hexagonal polygonal extrusions rotated at different angles.
I want to prepare them for laser cutting. I’m trying to orient them on xy plane but the trouble is that the orient component works only if I choose a one single surface instead of BREP.
What should I do so that all the hexagons are placed apart from each other on an XY plane?
How do I ensure that the orientation takes the hexagonal face as the plane of reference?
I actually simplified my problem by using simple geometry.
I am trying to re-orient rotated extruded volumes having curved parameter, on XY plane for fabrication. But I’m not able to put all those pieces at a distance apart on the plane. What should I do so that all these rotate geometry has their flat faces aligend with the xy plane in a parallel way so that I can sent the file for laser cutting fabrication?
ORIENT ATTEMPT 2.gh (11.7 KB)
MODEL 15 APRIL.3dm (9.6 MB)
