is there any chances to add a command for the future: random selection (with option to pick what % to be randomly selected from the whole scene). That would be really useful for artistic/design work. Thank you as always!!
This could be scripted.
import random
import math
a=rs.GetObjects(message="Select")
b = len(a)
c = rs.GetInteger("percentage")
percentage = int(math.ceil(b/100*c))
rs.SelectObjects(random.sample(a, percentage))
thank you Martin, I will try it out
Hi Martin,
Thanks heaps for the script; I use it a lot.
Is it possible to have a similar script; where instead of inputting a percentage, you can input a number of objects you want to select?
Best,
Jeremy
I think the sample function requires a number and the percentage input is converted into a number first.
That means you can replace the percentage input with just a number input.
Hi Martin, thanks for your reply,
When the script asks for a percentage, when you input a number (e.g., 45), it gives you 45% of the total number of objects. How do you put 45 as a number of objects you want selected?
Best,
Jeremy
I think this should do it:
import random
import math
c = rs.GetInteger("number")
rs.SelectObjects(random.sample(a, c))
Works perfectly :))
Thank you so much
-Jeremy
