Radius Gauges, 3D Printed
Built a full set of gauges for referencing radii on surfaces such as helmets. The gauges can be slotted at 90 degrees to check or measure curvatures in two directions. Convex and saddle surfaces can be checked with mating different sections.
Fully built geometry in Grasshopper, 3D printed, from a radius of 25mm to about 300 mm.
95mm x 95mm x 6mm
will you be releasing the files on a platform like thingiverse?
Possibly, considering on Sketchfab.
Just have to figure out how to get Grasshopper to upload the OBJ files to SketchFab and write the descriptions.
Everything else is automated, this step should be also.
