R8 - SmartTrack changes "diameter" to "radius" value
is there a way how to change this behavior?
Smart Track change dimensions from diameter to radius, or create whole “rectangle” without second dimension…It’s right behavior? If i have “radius” choice, then is everithing ok…
This is not smart this is frustrate behavior…:frowning:
smarttrack
Hello- I can’t repeat that here - the diameter shows correctly with or without smartTrack - but the clip is too small to see well, I am not sure what I am looking for.
Can you please give the steps to reproduce?
Hello @pascal,
if use right click and “save image as” then is posible to see bigger clip…
  • turn on SmartTrack and use choice “Smart ortho”
  • run circle command
  • use “diameter”
  • type diametr value (do not press enter)
  • find “some activation point of smart ortho”
  • the size of circle will changing to double value in these points
Got it, thank you.
RH-81183 SmartOrtho and distance constraint
RH-81183 is fixed in Rhino 8 Service Release 6 Release Candidate
Hi @brian
same problem have “Scale” command - if is SmartOrtho active - not working correct if are some points (directions) of SmartOrtho active…
RH-81183 is also fixed in Rhino 8 Service Release 6
I have experience the exact same bug in rhino 8
