I decided it was time to explore Class Methods in Python Enums. I can create a module with them and, while editing the module, Rhino 8’s autocomplete shows them. However, if I import the module into another .py file then autocomplete does not show them in that context. It does show the enum members.
Here’s a fragment of the class:
The class method base_unit() returns a particular enum member.
Here’s a small test py file which imports the module, showing how the autocomplete choices do not show the method:
Here’s the test file in Visual Studio, where the class method does appear in the autcomplete options:
Note that it is only the autocomplete that is a problem - if I type the code in manually it executes correctly.
Rhino 8.7.24128.12261, 2024-05-07
TestingClassMethods.py (156 Bytes)
dens.py (2.0 KB)
Regards
Jeremy
