jayson1
(Jayson)
1
Hi Good day to all,
I have some problem regarding the extrude curve tapered.
For context, I recently change from Rhino 6 to Rhino 8.
In Rhino 6, you can extrude curve tapered the curve in any direction you want.
But in Rhino 8, I cannot do this. I can only extrude it in the direction the curve is facing.
My curve is no flat. And I need the extrusion in certain direction.
Sorry i cannot describe it better in words.
Please see the attached file for the problem.
Thank you for anyone who will answer.
Best regards,
Jayson
wim
(Wim Dekeyser)
2
Hi Jayson -
You attached a couple of images but no 3dm file.
With the Direction
option, that seems to work fine in Rhino 8 in a quick test here:
jayson1
(Jayson)
3
Good Day @wim
Sorry for the late reply.
We don’t have problem with if it is rotated like the one of your example.
I attached a file for your reference on what our problem is.
Best regards,
jayson
extrude tapered problem.3dm (40.9 KB)
wim
(Wim Dekeyser)
4
Hi Jayson -
Thanks. I see that behavior here → RH-81559 ExtrudeCrvTapered: Direction fails
jayson1
(Jayson)
5
Hi Wim,
Thank you for checking my problem.
I check the link and seems that the problem is still not solved.
