Question - Lines, Circles and Loft Edges
Hellow!! I have some pipes that were built from circles and loft. When I want to change their height I usually take the edge and pull it where I want it, but it gets deformed. In this case, I must always be rebuilding the pipe. Is there any simple way I can do this without it deforming and I have to keep rebuilding again?
Hi Igor -
Yes, you can enable history before running the Loft command. You will then be able to move/modify the circles and the loft will automatically update.
It works! Thxx Wim!
