Query block instances to place text and load a picture from folder?
I’m trying to build a small Grasshopper workflow in Rhino where I automatically collect lighting objects from my model.
My setup is:
• Lighting fixtures are block instances
• Block names start with a prefix, for example:
el-spot
el-roof
el-wall
Each block instance also has User Text attributes, for example:
ID = spot
TYPE_ID = SPOT_SASSO60
In addition, I have a folder with images of the fixtures, where the image names correspond to the TYPE_ID values.
For example:
In case you are you using Rhino 8, look at the Grasshopper Rhino components.
