In QuadrangulateMesh options Rhino 6 has the following options:
Planarity
Rectangularity
Increment
When I read associated help everything is clear but I have no clue why I should input any value into “Planarity” input instead of inputting “Rectangularity” only. Planarity is simply given by the information about neighbouring triangle faces in the original file - there is nothing to adjust here.
What in fact is the difference between the values to be input into these two windows?
And what are spinner controls?
Planarity
The angle between the face normals of the triangles.
Rectangularity
Specify a number greater than or equal to 1. If the adjacent triangles pass the planarity test then they will be merged into a quadrangle if the largest ratio of the lengths of the diagonal is less than or equal to the number you typed, then the triangles are converted to quadrangle.
Spinner controls are the up and down arrows next to the numeric input fields.
If Increment is set to 1, pressing the up arrow will increase the value by 1. If it is set to 10, the value will increase by 10 for each mouse-click.
Adjacent triangles will be merged into a quadrangle if the largest ratio of the lengths of the diagonal is less than or equal to the number you typed.
This is about the shape of the triangles. If you want to allow long and skinny quads, you’ll have to increase this value. The numbers in the following picture are the largest ratios of the lengths of the diagonals:
May just be me, but QuadrangulateMesh doesn’t seem to be autocompleting. Is it being hidden by design? That functionality seems sort of tucked into Mesh2. Is it redundant?
In WIP 7.0.20133.11585, 12/05/2020. At first I thought it had maybe just gone but I typed it in regardless (as QuadRangulatemesh)
Users are getting confused between the old QuadrangulateMesh and the new QuadRemesh commands. We feel QuadRemesh is much better and that’s what will make users the happiest.
