Q: Rhino mesh to Revit, how avoid mesh wires?
Hi, any Revit gurus here?
We are exporting landscapes as meshes to IFC, but when the Architects add these to Revit the mesh wires are always visible. Is there a quick setting or workaroud for them to make the objects appear cleaner?
The meshes are welded at 22 degrees, so the top surface of the topography *should* be smooth, but I don’t know how Revit reads in meshes.
Thanks for any hints and all help.
Depends on the Revit version (2023+). In the newer versions you have more control.
I’ll pass that along and we’ll see. Thank you.
