Hi friends,
I came arcoss with one problem about the Region Difference component. The output is not coplanar with the input. Is it a bug or I just miss something? See picture below.
Region Differentce problem.gh (446.9 KB)
Hi friends,
I think this is within tolerance…
Thanks for your quick reply.
I just baked the curves and measured the gaps which is 0.01 unit while the tolerance is 0.001 unit.
The gaps is about ten times the tolerance,so I think it is not within tolerance.
When I open your GH file in R7, I get an endless loop of this message:
Switching to R8, it’s hard to be sure your curves are coplanar:
Evaluate Surface isn’t really necessary, eh?
In fact, there are different gaps. I just baked all the curves and you can test again.
Region Difference problem.3dm (1.6 MB)
I see. 77 mm isn’t a tolerance issue
Your own image says they are not all planar. See version ‘b’ added to my previous post.
OK.Thanks.I did not notice that not all of the input curves are planar.Maybe it is the root cause of this problem.
I will try to make all the input curves planar and see whether or not the result would become right.
This is the problem
I’ve looked more closely and see issues with your geometry.
Yes, I recommend the following:
Thanks.
This is really helpful.
Hi Joseph,
Your solution is very good but it is not suit my need this time.
In fact,I want to generate one brep with 6 faces, all of which should be planar. So I can not project curves for it would affect other faces of the berp.See attached picture and def.
Why then would I offer more?
Thanks.
I did not notice that only one face of the brep in my def is not planar while the other 5 faces are planar. Now the question is how to make every face of the brep is planar?
Can you have a look at this post? I need your help. Thanks.
Just pull everything which is not planar to a plane?
Sorry. I will try other ways by myself instead of asking again and again.
