I don’t understand the sort method in python, and i need today to sort geometry with the X value and the Y value.. for example i select circles, and i need that python sort them like this:
you can sort by multiple arguments either with a comparison function or using a lambda like below. Note that sort does sort an interable in place while sorted would create a sorted copy:
import Rhino
import scriptcontext
tolerance = scriptcontext.doc.ModelAbsoluteTolerance
def circle_filter(rhino_object, geometry, component_index):
rc, circle = geometry.TryGetCircle(tolerance)
return rc
def DoSomething():
msg = "Select circles to sort"
obj_ids = rs.GetObjects(msg, 4, True, False, False, None, 2, 0, circle_filter)
if not obj_ids: return
rh_objs = [rs.coercerhinoobject(obj_id, True, True) for obj_id in obj_ids]
rh_objs.sort(key=lambda c: (c.Geometry.Arc.Center.Y, c.Geometry.Arc.Center.X))
for i, rh_obj in enumerate(rh_objs):
rs.AddTextDot(i, rh_obj.Geometry.Arc.Center)
DoSomething()
Since the origin is at the lower left in Rhino, you would negate the first item in the sort tuple to get what you want, it has the origin in the upper left:
using curves instead of circles, you can provide a custom SortFunction to your sort as the key argument like this:
import Rhino
def DoSomething():
msg = "Select cures to sort"
obj_ids = rs.GetObjects(msg, 4, True, False, False, None, 2)
def SortFunction(rh_obj):
bbox = rh_obj.Geometry.GetBoundingBox(True)
return (-bbox.Center.Y, bbox.Center.X)
rh_objs.sort(key=SortFunction)
rs.AddTextDot(i, bbox.Center)
DoSomething()
This will sort by the BoundingBox.Center in the WorldXY plane. Note that the SortFunction also returns a tuple where the first item is the negative Y axis and the second item is the positive X axis, so your origin is at the upper left.
To use the lower left of the bounding box you would just change the SortFunction to look like this:
Hi Clement-
Is there a way to select all the sorted objects one by one using this script?
I’ve got a bunch of groups packed into blocks, and I’d like to select them one at a time from left to right, based on their X position – kind of like I’m clicking on each one of them with the mouse, one by one..
import scriptcontext as sc
import Rhino
def DoSomething():
obj_ids = rs.GetObjects(msg, 4096, True, False, False, None, 2)
rs.SelectObject(rh_objs) #Yeah, sorta like that#
DoSomething()
Hi @leex, if rh_obj is your sorted object, you could use rs.SelectObject(rh_obj) in that loop. Maybe add a rs.Sleep(500) too in the next line so you can see how it selects eg:
rs.Sleep(500)
