Sorting points by Y axis
Hi everyone,
I bumped into an issue about sorting points, as attached screenshot shown, I’d like to sort the points to the Y-Axis first instead of the default logic (first x, then y, then z)
Before when using lunchbox to do such thing, i can use reverse surface direction to change to sorting, but this time it’s only points and so far i had no luck to get it done.
Would be nice if anyone can give me some hint
cheers.
Sorting points_Y first.gh (39.7 KB)
This might do it:
Hi Anders thanks for the quick reply!!
I tried to hook it up into my file and got this result, any clue?
Hello
do you want something like that ?
If so it seems you didn’t’ really read what was here. I used David Rutten Method that uses a single number calculated with a formula like (Pt.X+1000*Pt.Y)
If you invert X and Y
it is also possible to remap value in order to have just positive values and no surprises!
Sorting points_Y first.gh (39.5 KB)
thank you Laurent, this is exactly i was aiming for. Somehow I overlooked David’s approach but now i get the desired result.
Will also study a bit the script you provide.
Thank you!
Ah sorry I missed the “first Y, then X” part, and obviously the topic was already solved. But just for completeness, one could extend the script I posted like so:
181011_SortPointsByYThenX_00.gh (35.2 KB)
Thank you Anders, this way also works.
I appreciate the different approach you showcased!
