I tried running the sample script in the help file, and Snap doesn’t seem to be working.
if not rs.Snap(): rs.Snap(True)
If I turn it on manually and go the other way (attempt to shut it off) it still doesn’t work.
if rs.Snap(): rs.Snap(False)
Thanks,
Dan
Doing a little investigating I find that the problem is in the application.py script. I believe “modelaid” should be “ModelAidSettings”.
This script toggles the Snap on and off:
import Rhino
if Rhino.ApplicationSettings.ModelAidSettings.GridSnap == False:
Rhino.ApplicationSettings.ModelAidSettings.GridSnap = True
elif Rhino.ApplicationSettings.ModelAidSettings.GridSnap == True:
Rhino.ApplicationSettings.ModelAidSettings.GridSnap = False
Thanks,
Dan
dale
(Dale Fugier)
3
Got it, thanks for reporting.
– Dale
