Hi @Alain,
there seems to be a “bug” with rs.ObjectsByType() method in python, it does not list any objects placed on hidden layers. eg. using the code below:
ids = rs.ObjectsByType(8 + 16 + 32, state=0)
with state=0, i get zero objects returned, compared to RhinoScript (vb), when i use this code:
Call Main()
Sub Main()
Dim objs
objs = Rhino.ObjectsByType(8 + 16 + 32)
If IsNull(objs) Then
Rhino.Print "No Objects found"
Else
Rhino.Print "Objects found: " & UBound(objs) + 1
End If
End Sub
Objects on hidden layers are returned. IMHO Python behavior should not be different to RhinoScript (vb).
What do you think ?
c.
