Rhino works perfect, Grasshopper works perfect, Python works perfect, but I am doing something wrong again.
How to convert Guid objects to curves?
I made a screenshot of a part because the script is to large.
Thank you for your response.
You need to give us a slightly bigger hint on what you are trying to do - what do your guid objects represent? Points?
What type of curve do you want to create? A straight line between 2 points?
A curve from a python list of point guids?
I did
curve = rs.AddLine(pnA, pnB)
From it a Guid object is created. What am I doing wrong? The manual says that the function creates a Guid too. But, how do I output it as a curve?
You’re returning a function, not a guid nor a RhinoCommon object (e.g. a curve). Again, it is literally impossible for anyone to help without you uploading a (minimal) executable example to troubleshoot.
Okay, I made something that creates the similar problem. So, how can I get the curves out of it? Do you might know?
20190122 problem ironpython 00.gh (7.7 KB)
Hi try adding () after your function call to run the function g.make_lines()
Otherwise you are assigning the function to lines. I get a group of Ironpython lists this way
By the way, you can use zip() or izip() to achieve crossline more efficiently:
from itertools import izip
def crossline(self, pntsx, pntsy):
lines = []
for x,y in izip(pntsx, pntsy):
line = rs.AddLine(x, y)
lines.append(line)
return lines
or in a line:
def crossline(self, pntsx, pntsy): return [rs.AddLine(x,y) for x,y in zip(pntsx, pntsy)]
So, do you might know how I can get curves out of those IronPython lists?
Assuming it is a two-dimensional python list (of lists of curves), you could either flatten the list (i.e. make an empty list, iterate your curves lists, and extend the empty list with these) or convert it to a DataTree (using the data tree helpers, or like so).
I am still doing something wrong.
Yes, it is a list of curves, but I do not know how to retrieve it.
20190122 problem ironpython 01.gh (9.4 KB)
Your stepa variable is not a list of lists of curves, it has both single elements and lists:
Knowing how to inspect your variables and check your assumptions is step #1 in debugging.
Probably you need to call extend instead of append. (if nested list was intentional and how to convert it to GH_Tree was the main question, just disregard this post…)
lines=self.line(self.pntsa) #lines is a list of lines
self.alllines.extend(lines) #call extend instead of append. You will get a flattened list.
But something strange for me is that “lines” are already added to alllines in function self.line().
Two solutions from me.
Thank you
