[python] How do I delete block definitions
How do I delete block definitions using blocks_table.Clear() but only after reassuring that all blocks have been exploded?
I need to be sure no geometry objects are inside any block before deleting.
Do I need to loop through all blocks and check if there’s something inside?
You can easily use Purge command.
Thanks for the suggestions @Mahdiyar, but I do not want to delete empty layers and stuff
You can change this command settings to get the result you’re looking for:
_Purge _BlockDefinitions=Yes _AnnotationStyles=No _Groups=No HatchPatterns=No _Layers=No _Linetypes=No _Materials=No _Enter
Thanks I solved it:
import scriptcontext as sc
def blockaecide():
    block_obj_inst_id = rs.GetObject("Select Block: ", rs.filter.instance)
    rs.ExplodeBlockInstance(block_obj_inst_id,explode_nested_instances=True)
    blocks_leftovers = [block_obj for block_obj in rs.AllObjects() if block_obj is rs.filter.instance]
    blocks_table = sc.doc.InstanceDefinitions
    print len(blocks_leftovers)
    print len(blocks_table)
    if len(blocks_leftovers) == 0 and len(blocks_table) != 0:
        sc.doc.InstanceDefinitions.Clear()
if __name__=="__main__":
    blockaecide()
