Is this an issue?
How can I apply the extrude to all sub-surfaces in the polysurface without exploading?
import Rhino.Geometry as rg
a = []
for face in x.Faces:
normal = face.NormalAt(0,0)
centroid = rg.AreaMassProperties.Compute(face).Centroid
profile = rg.Line(centroid, centroid+normal*y).ToNurbsCurve()
a.append(face.CreateExtrusion(profile, False))
IVELIN PEYCHEV.gh (13.5 KB)
@Mahdiyar, do you read minds
I was about to ask (create a new thread) about how can I do an extrude by a vector instead a line.
You probably can’t, since the CreateExtrusion
method, needs a path curve to extrude along, called “profile” in @Mahdiyar’s code.
public Brep CreateExtrusion(
Curve pathCurve,
bool cap
However, the profile line is created with a vector. This vector is the normal
scaled by y
. It is then added to the centroid, to produce the path curve end point at the peak of the vector.
You could refractor the code like this:
a = []
centroid = rg.AreaMassProperties.Compute(face).Centroid # path curve start point
vec = normal * y # scaled normal vector
end_pt = vec + centroid # path curve end point
path_crv = rg.Line(centroid, end_pt).ToNurbsCurve()
a.append(face.CreateExtrusion(path_crv, False)) # True for caps
You could also convert the face to a surface - face.ToNurbsSurface() - then use Surface.CreateExtrusion() which takes a vector. However, there is no option to cap in this case. You could also get the edges of the surface (if no holes) and use Extrusion.Create() which does have the Cap option.
in case I prefer this approach, how can I get this face in RhinoScriptSyntax to extrude it with rs.ExtrudeSurface?
Don’t bother, since ExtrudeSurface
from rhinoscriptsyntax does exactly the same thing as @Mahdiyar proposed about, as you can see below (or on GitHub):
def ExtrudeSurface(surface, curve, cap=True):
"""Create surface by extruding along a path curve
Parameters:
surface (guid): identifier of the surface to extrude
curve (guid): identifier of the path curve
cap (bool, optional): extrusion is capped at both ends
Returns:
guid: identifier of new surface on success
Example:
surface = rs.AddSrfPt([(0,0,0), (5,0,0), (5,5,0), (0,5,0)])
curve = rs.AddLine((5,0,0), (10,0,10))
rs.ExtrudeSurface(surface, curve)
See Also:
ExtrudeCurve
ExtrudeCurvePoint
ExtrudeCurveStraight
brep = rhutil.coercebrep(surface, True)
curve = rhutil.coercecurve(curve, -1, True)
newbrep = brep.Faces[0].CreateExtrusion(curve, cap)
if newbrep:
rc = scriptcontext.doc.Objects.AddBrep(newbrep)
scriptcontext.doc.Views.Redraw()
return rc
