Dear community,
Is there a python equivalent of the LineBetweenCurves method in Rhinoscript?
Thanks in advance.
Kind regards,
Filip
Dear community,
Thanks in advance.
Kind regards,
Filip
Use Rhino.Geometry.Line.TryCreateBetweenCurves.
Thanks for the reply.
Is there also a simple way to convert a GUID string referring to a curve to an actual RhinoCommon curve object?
I found something using the utility module
import utility as rhutil
crv = rhutil.coercecurve(...)
However, then I am stuck getting the message “No module named utility”. So how can I import utility.py in a sustainable way without file copying between folders?
Thanks in advance.
Kind regards,
Filip
That can be done something like this:
import scriptcontext as sc
obj=sc.doc.Objects.find(objID)
crv=obj.Geometry
–Mitch
OK, thanks Dale and Mitch.
Thanks to you, it now works
