[GhPython] Convert PolyCurve to GUID?
I can’t find a way to convert a polycurve into a guid. I want to use rs.SimplifyCurve() on a polycurve but the error says it couldn’t be converted to guid. Is it impossible to convert polylines to guids? Is there any way around this?
(rs.coerceguid(polycurve) returns NoneType: )
PolyCurvesToGUID
Hi @joshuaterranova01,
You cannot convert a curve to a GUID. But if you add the curve to the document, the newly added curve object will be assigned a GUID, which you can then reference from rhinoscriptsyntax.
If that’s too much, then just use Curve.Simplify.
– Dale
You probably don’t need to convert it, check this out instead:
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Curve_Simplify.htm
Thank you for the help! I’ll try the Simplify. For future reference, how would I add a curve in a python script to my document, thus assigning it a GUID?
If you like using rhinoscriptsyntax, then you can use one of the many "rs.Add` functions.
https://developer.rhino3d.com/api/RhinoScriptSyntax/#curve
Otherwise, just add it to the document’s object table using ObjectTable.AddCurve.
import Rhino
import scriptcontext as sc
sc.doc.Objects.AddCurve(pOffset)
sc.doc.Views.Redraw()
