Python doesn't work, help me fix the code
Hi everybody
I followed the video tutorial but did not return the desired results
Can someone fix the code for rihino 6?
Could you post your Rhino file and say precisely what you tried to do, how you tried to do it and what was wrong with the result?
Graham
OK maybe someone will take the time to do all of that for you :slight_smile:
In general, in my experience on this forum, you are more likely to get help if you do a bit more work yourself to make it easier for others.
Good luck !
Graham
