Hello everyone,
I am relatively new to python and also the use of classes. I am trying to put the values from a class in an empty list. For some reason im getting “<main.DataSet instance at 0x000000000000AEE3>” as the output instead of in this case a list of 2’s. Can someone explain to me what this means?
python_class.gh (6.0 KB)
You are outputting a class instance (i.e. that has a
, b
, c
, d
properties with the value 2). It might cause less confusion if you inherent from the base .NET object
class:
Edit: Here’s a quick update that might help your learning:
230333_PythonClass_00.gh (5.5 KB)
Thanks for that second part, ill try and play around a bit with this to understand it.
Kind regards,
