Does there exist something like a python center box?
I can easily fix the problem in the image, but I want to be sure that I am not working inefficient.
0100 python centerbox.gh (8.6 KB)
I don’t think so. Might be a good idea to use VectorAdd with b being an input (point).
boxPts = []
boxPts.append(rs.VectorAdd(b, (x/2, y/2, -z/2)))
boxPts.append(rs.VectorAdd(b, (x/2, -y/2, -z/2)))
boxPts.append(rs.VectorAdd(b, (-x/2, -y/2, -z/2)))
boxPts.append(rs.VectorAdd(b, (-x/2, y/2, -z/2)))
boxPts.append(rs.VectorAdd(b, (x/2, y/2, z/2)))
boxPts.append(rs.VectorAdd(b, (x/2, -y/2, z/2)))
boxPts.append(rs.VectorAdd(b, (-x/2, -y/2, z/2)))
boxPts.append(rs.VectorAdd(b, (-x/2, y/2, z/2)))
a = rs.AddBox(boxPts)
you could also use rhinocommon
import Rhino.Geometry as rg box = rg.Box( plane, rg.Interval(-0.5*x,0.5*x), rg.Interval(-0.5*y,0.5*y), rg.Interval(-0.5*z,0.5*z)) a = box;
Do you know how to make a plane to use that box?
I know having a problem of creating a non-type as a plane.
python box 01.gh (6.1 KB)
option 1.) create a new input parameter with name “planeBox” with type hint “Plane”.
option 2.)
import Rhino.Geometry as rg planeBox = rg.Plane( rg.Point3d (4.0,2.0,1.0), # Origin rg.Vector3d(1.0,0.2,0.0), # xAxis rg.Vector3d(0.2,1.0,0.0)) # yAxis(Other overloads are possible)
Maybe just some additional notes:
I’m primarily coding in C#, so I’m more used to Rhinocommon instead of Rhinoscriptsyntax.
Rss is a wrapper library around Rhinocommon, to allow calling its functionality in a more “pythonic” way. However: Rss does not cover every Rhinocommon functionality. If you know how to work with Rhinocommon, you definitely have a richer toolset.
Rhino.Geometry is part of Rhinocommon. Most Grasshopper components are simple Rhinocommon calls. So if you look out for GH functionality, there is a high chance of a Rhinocommon equivalent.
here is the online sdk for Rhinocommon:
https://developer.rhino3d.com/api/RhinoCommon/html/N_Rhino.htm
and here the entry for the Plane Structure:
https://developer.rhino3d.com/api/RhinoCommon/html/T_Rhino_Geometry_Plane.htm
