Python 3 controlling a Number Slider
Hello fellow designers and coders,
I am new to python especially the 3.0 implemented within grasshopper within Rhino 8.0
Very curious about the possibility to have a python component read a slider either current, min and max values and then generate steps based on a Component ie float names Frames that can push the slider from its min to max value by a function such as steps = (Max-min)/Frames
I think it’s clear I am working on a animation component and am having come issues with this last part.
This is what I have thus far:
from decimal import Decimal, getcontext
import Grasshopper as gh
from Grasshopper.Kernel.Special import GH_Group, GH_NumberSlider
import System
# Set decimal precision
getcontext().prec = 28
def safe_decimal(val):
"""Convert ANY numeric type to Python Decimal"""
if val is None:
    return Decimal('0')
try:
    if hasattr(val, 'ToString'):  # .NET object
        return Decimal(str(val))
except:
    return Decimal('0')
def safe_int(val):
"""Convert ANY numeric type to int"""
if val is None:
    return 0
try:
        return int(float(str(val)))
    return int(float(val))
except:
    return 0
def to_net_decimal(val):
"""Convert Python Decimal to System.Decimal for Grasshopper outputs"""
if val is None:
    return System.Decimal(0)
try:
    return System.Decimal(float(val))
except:
# Convert inputs
Frames = safe_decimal(Frames) if ‘Frames’ in locals() else Decimal(‘50’)
i = safe_int(i) if ‘i’ in locals() else 0
group_name = str(group_name) if ‘group_name’ in locals() else “Animate”
doc = ghenv.Component.OnPingDocument()
found_slider = None
min_val = max_val = step = None
current_val = None
slider_name = None
frame_idx = 0
if doc:
for obj in doc.Objects:
    if isinstance(obj, GH_Group) and str(obj.NickName) == group_name:
        for comp in obj.Objects():
            if isinstance(comp, GH_NumberSlider):
                found_slider = comp
                break
    if found_slider:
        break
if found_slider and Frames > 0:
\# Read slider bounds
min_val = safe_decimal(found_slider.Slider.Minimum)
max_val = safe_decimal(found_slider.Slider.Maximum)
\# Compute step
if Frames > Decimal('1'):
    step = (max_val - min_val) / (Frames - Decimal('1'))
else:
    step = Decimal('0')
\# Clamp frame index
max_frame = min(safe_int(Frames), 999999)
frame_idx = max(0, min(safe_int(i), max_frame - 1))
\# Compute target value
target_val = min_val + (step \* Decimal(frame_idx))
\# Set slider value (must be float for .NET)
found_slider.Slider.Value = float(target_val)
found_slider.ExpireSolution(True)
current_val = target_val
slider_name = str(found_slider.NickName)
# CRITICAL FIX: Convert ALL outputs to System.Decimal
a_min = to_net_decimal(min_val)
a_max = to_net_decimal(max_val)
a_step = to_net_decimal(step)
a_val = to_net_decimal(current_val)
a_idx = frame_idx # This is already int, safe
slider_name = slider_name if slider_name else “”
Current issue:
Traceback (most recent call last):
File “rhinocode:///grasshopper/1/58edebc1-834a-4506-b38e-b45c3c5b0e5e/bbac34bc-7726-4a2f-85f8-aabeac8647f1”, line 81, in
TypeError: ‘float’ value cannot be converted to System.Decimal
I would be glad to share the final animation code as I believe it would benefit the entire community!
Best regards and thanks for your contribution,
Andres
PS this was a second attempt but it didn’t work - for same reason.
GHPython (Python 3) - Slider Animator
Rhino 8.0 compatible - uses proper .NET interop patterns
Based on McNeel Discourse best practices
import System
def safe_float(val, default=0.0):
"""Convert any numeric type to float safely"""
if val is None:
    return default
try:
    \# Handle .NET types
        return float(str(val))
    return float(val)
except:
    return default
def safe_int(val, default=0):
"""Convert any numeric type to int safely"""
if val is None:
    return default
try:
except:
    return default
# ========== INPUT HANDLING ==========
frames_count = safe_int(Frames, 50)
frame_index = safe_int(i, 0)
# ========== INITIALIZE OUTPUTS ==========
a_min = None
a_max = None
a_step = None
a_val = None
a_idx = 0
slider_name = “”
# ========== FIND SLIDER IN GROUP ==========
found_slider = None
if doc:
                found_slider = comp
                break
    if found_slider:
        break
# ========== COMPUTE AND SET VALUE ==========
if found_slider and frames_count > 0:
\# Get slider properties as floats (native Python)
slider_min = safe_float(found_slider.Slider.Minimum)
slider_max = safe_float(found_slider.Slider.Maximum)
\# Compute step size
if frames_count > 1:
    step_size = (slider_max - slider_min) / float(frames_count - 1)
else:
    step_size = 0.0
clamped_index = max(0, min(frame_index, frames_count - 1))
\# Compute target value (pure float arithmetic)
target_value = slider_min + (step_size \* float(clamped_index))
\# KEY FIX: Set value as double (float in Python)
\# Grasshopper's Slider.Value property expects double, not Decimal
found_slider.Slider.Value = target_value
\# Expire the slider to trigger recalculation
\# Set outputs (keep as float - Grasshopper handles conversion)
a_min = slider_min
a_max = slider_max
a_step = step_size
a_val = target_value
a_idx = clamped_index
# If slider not found, outputs remain None/0/“”
