Purge 'used' views
I’d like to purge all views in a project, even if they are in use.
Im not able to delete the ‘used’ views, is there a way around this?
Also, I have noticed that some views come up as ‘in use’ even though they are not on drawing sheets?
Many thanks,
Stephan
Hi Stephan,
Delete Element would work well in this scenario, just remove the active view and any others you want to keep.
Hi Japhy,
thanks for this.
This seems to work really well for sheets but not always for views. Any idea why they cant be delete?
Cheers,
Stephan
I’ve just noticed that adding the ‘view family’ allows my to eventually delete all of the views.
I thought that if i dont use the ‘view family’ component than it would select all of them by default but that doesnt seem to be the case?
