Pull Points - Perpendicular (Closest Perp, Not just closest)
I want to achieve what pull points does, and it is working perfectly, but I want to find the nearest perpendicular point, not just the nearest point. What should I do?
what’s the geometrical context of your question?
could you please post some geometries and point to work with?
do you mean perpendicular to the geometry the Point eventually lies on? or perpendicular to the geometriy on which the search has to be performed?
I have curves in 2D. I want to obtain the closest perpendicular point on Curve A (blue line) from a divided point on a Curve B (red line). In my figure the lines are doing between closest points, when I want them to be perpendicular to closest points from the red line.
please do not open identical threads as multiple users
