@eirannejad
One additional question as I play around with the script editor which I’m hoping you have answer to.
I had couple code that inherited the original component methods and modified it which was working fine in the old compiling method but seems to have issue rendering using the new script editor method. Do you know why this might be happening? Below is one example where it inherits and creates a physical button but seems like this does not work anymore with the R8 script edidtor
from ghpythonlib.componentbase import executingcomponent as component
import Grasshopper, GhPython
import System
class Button_UI(Grasshopper.Kernel.Attributes.GH_ComponentAttributes): # inherits all methods of GH_ComponentAttributes
def __init__(self, owner):
super(Button_UI, self).__init__(owner)
self.component = owner
self.button_down = False
def Layout(self): # override inherited method Layout
Grasshopper.Kernel.Attributes.GH_ComponentAttributes.Layout(self)
component_rect = Grasshopper.Kernel.GH_Convert.ToRectangle(self.Bounds)
component_rect.Height += 22
self.button_rect = System.Drawing.Rectangle(component_rect.X, component_rect.Bottom-22, component_rect.Width, 22)
self.button_rect.Inflate(-2, -2)
Bounds = component_rect
self.Bounds=Bounds
ButtonBounds = self.button_rect
self.ButtonBounds=ButtonBounds
def Render(self,canvas, graphics, channel): # Override Render method
Grasshopper.Kernel.Attributes.GH_ComponentAttributes.Render(self, canvas, graphics, channel)
if channel == Grasshopper.GUI.Canvas.GH_CanvasChannel.Objects:
color = Grasshopper.GUI.Canvas.GH_Palette.Grey if self.button_down else Grasshopper.GUI.Canvas.GH_Palette.Black
button = Grasshopper.GUI.Canvas.GH_Capsule.CreateTextCapsule(self.ButtonBounds, self.ButtonBounds, color, "Button", 2, 0)
button.Render(graphics, self.Selected, self.Owner.Locked, False)
button.Dispose()
def RespondToMouseDown(self,sender,e):
if e.Button == System.Windows.Forms.MouseButtons.Left:
rec = self.button_rect
pt = System.Drawing.Point.Round(e.CanvasLocation)
if not self.button_down:
if pt.X > rec.X and pt.X < rec.X+rec.Width and pt.Y > rec.Y and pt.Y < rec.Y+rec.Height:
self.button_down = True
self.component.OnDisplayExpired(False)
return Grasshopper.GUI.Canvas.GH_ObjectResponse.Capture
return super(Button_UI, self).RespondToMouseDown(sender, e)
def RespondToMouseUp(self,sender,e):
if self.button_down:
self.component.click_response()
return Grasshopper.GUI.Canvas.GH_ObjectResponse.Release
return super(Button_UI, self).RespondToMouseUp(sender, e)
class MyComponent(component):
def __init__(self):
self.click_count = 0
def CreateAttributes(self): # Override inherited method create attributes
self.m_attributes=Button_UI(self)
def RunScript(self, x, y):
return self.click_count
def click_response(self):
self.click_count += 1
self.ExpireSolution(True)
In R7 the inherit and override after compiling seems to work
But in R8 the override does not take effect
I’m I missing something here? Than you in advance again!
