Hi, What command to project an object to Cplane using its centre, or centre of gravity, in my case its a pipe command result based on a planar curve.
Steve
Steve
Use VolumeCentroid, which will create a point at the volume center, and then Move to move the object from that point to 0.
–Mitch
Or if the object is an open surface use AreaCentroid instead of VolumeCentroid
Hi
Many thanks.
Steve
