Hi @René_Corella Sincere apology for the confusion caused by intention to minimize others time and to get to the main point directly instead going from scratch. well i really appreciate and thankful for your time and efforts. i will check and see if this will workout.
Again thanks alot.
M.Ismail .
Just fyi:
There seems to be some issues with the meshing of objects:
This improves a bit if you tweak render mesh quality in the Rhino options:
This is rather silly but if you explode the breps and re-surface the faces Rhino likes it more:
Just make sure you join them again I guess.
Also please note this script and efforts are for Bridge modeling so direct vertical projections will not work from 0 plane upwards towards bridge vertical profile depends on it elevation height and vertical curve. it might be more than hundred meter up but also we cannot manipulate 0 point objects by raising them up closer to bridge designed curve. well that will impact the railings spacing.
Sure thing - thanks - I’m working on a bridge project soon so I’m learning from this stuff - I bet I’m destined to fail.
i can share any knowledge regarding that if needed but not GH sorry. Hehehe
Anyway … the Transformation is still unclear to me.
Other than that get the attached (a 100% black box to you since it’s pure code) that does the plane to plane Trans using the projRail tangent projected to Plane.WorldXY - as vx - and the CrossProduct (tangent, global Z) - as vy. All that related with the planeTo List. The planeFrom is ALWAYS Plane.WorldXY (see where OEM geom is).
Pts/Planes on the flat rail are not required at all.
Curve_ProjToSurfAndPlaceGeo_V1.gh (20.0 KB)
Note: all placed Geom pair pts are at Distance D along the projected Rail.
Note: In real life we always use Instance Definitions notably if the Geom is “complex” and N is big.
Note: so we don’t have any projection of position pts: we just have properly spaced (along) points, properly defined planes and a Transformation.
Thanks @PeterFotiadis it not helpful either.
Oops the script came with typos: the group on the top is supposed to be titled “with profiles kept separate” referring to your two curves getting turned into the solids. I wasn’t sure if you meant to unify them or not.
Thanks it fantastic and clear but one thing is missing is the rail post. Most important item.
It’s not that it’s missing - I saw it - I just didn’t do anything about it - I was just trying to clean things up a bit - you can apply same method to orient that guy.
What I mean is that in reality it doesn’t come in because you’re using some component I don’t have:
Maybe internalize it so it’s saved within the script for the purposes of uploading here.
Ohh sorry. it Elefront tools for blocks etc. i will do it now.
Deck with Post).gh (137.4 KB)
Nice work @mainisl2 - show us what happens next!
Good luck.
