I’ve run into some issues with viewport clipping in Rhino 7. In my opinion, it’s quite similar to a problem I’ve encountered in 3ds Max. However, the solution in 3ds Max is relatively straightforward, as it involves using the viewport clipping setting. Does Rhino offer a similar option? This problem appears in Rhino when I start working on something far from the origin plane.
hi @Georgii_Butko pls run _SystemInfo and post back the results. Additionally, it would be helpful to send the 3d model as well.
Are your objects far away from the World Origin?
