Problems with lofts and empty space
Hello, I have a little bit of an issue regarding lofts and understanding how they work.
I have two close curves that I lofted together to create an autogenerated joint. The joint itself is perfect, however I have issues 3d printing this part and converting it into an stl. The loft creates a skin, that is essentially ‘0’ thickness. I would like to have a solid interior, and was wondering if there is a way to use loft specifically to create that solid interior.
Once I have created my loft, is there a simple way of filling the interior of that “shell”? I understand that I may be confusing how fusion 360 treats solids compared to rhino. What I have tried so far has been to use CAP, to create a closed 3D object, but that only goes so far.
Attached is the file that I am working with. I am not using grasshopper, but recognize that it would help to switch over to that. In the mean time, what’s the best way to make a solid object for 3d printing?
wing mount
There is no such thing as “filling” a solid, a ‘solid’ is simply an enclosed volume, and this is true in all CAD. Even voxels are closer to a cloud of points.
3d printer slicing apps have many, many, MANY settings for wall thicknesses and patterns for filling in volumes. It’s best to just worry about that there.
I see, so it would be easiest to just go through my slicer software.
Unless you’re attempting to actually simulate an injection-molded part, yes…well even in that case yes, it’s what determines how things get filled in.
thank you, appreciate the quick response!
You must use “loft” to create the joint
Then you must use the command “_OffsetSrf” to give that surface a thickness
You can then run your object through a slicer.
