Problems with ETO GitHub Examples
I’ve spent a couple frustrating hours starting to learn ETO with Python3. I have gotten a grand total of zero example scripts to work! Not a good average.
From here:
I have tried these scripts with and got the following errors
SampleEtoCollapsibleDialog.py
NameError: name 'Padding' is not defined
SampleEtoDialog.py
NameError: name 'Dialog' is not defined
SampleEtoRebuildCurve.py
SampleEtoViewports.py and SampleEtoViewCaptureDialog.py
Rhino.Runtime.Code.Execution.ExecuteException: Object reference not set to an instance of an object.
 ---> System.NullReferenceException: Object reference not set to an instance of an object.
   at Eto.Forms.Window.set_Title(String value) in D:\BuildAgent\work\dujour\src4\DotNetSDK\Eto\src\Eto\Forms\Window.cs:line 244
   at InvokeStub_Window.set_Title(Object, Object, IntPtr*)
   at System.Reflection.MethodInvoker.Invoke(Object obj, IntPtr* args, BindingFlags invokeAttr)
--- End of stack trace from previous location ---
   at Python.Runtime.PythonException.ThrowLastAsClrException()
   at Python.Runtime.PythonException.ThrowIfIsNull(NewReference& ob)
   at Python.Runtime.PyModule.Execute(PyObject script, PyDict locals)
   at Python.Runtime.RhinoCodePythonEngine.RunScope(Object scope, Object code, String pythonFile, String beforeScript, String afterScript)
   at Rhino.Runtime.Code.Languages.PythonNet.CPythonCode.Execute(RunContext context)
   at Rhino.Runtime.Code.Code.ExecTry(RunContext context, IPlatformDocument& doc, Object& docState)
   at Rhino.Runtime.Code.Code.Run(RunContext context)
   --- End of inner exception stack trace ---
Am I missing some kind of secret decoder ring to make the examples work?
The Rhino version is Version 8 SR8
All of these scripts are 6 to 7 years old, so maybe I have just followed the documentation to the wrong location?
Thanks for the insight,
Henry
I copy and paste into Rhino 8 and get this:
The 8.x version is a bit older. Running a check for update may help.
Is there anything different with the screenshot above?
Some of the more sophisticated examples do through some errors because of function overload syntax. I can take a look at that.
Well, I don’t know how to explain it, but I restarted Rhino and now the “basic” example works but the other ones still do not. The only change is that I closed Rhino and started it again. It seems worse to have something that works intermittently.
Here are a couple images to prove that I am not crazy…
Here is a quick brute force way to fix the Collapsable.
The Print method syntax and the multi-property control overloads are changed:
#! python3
# SampleEtoCollapsibleDialog.py
# MIT License - Copyright (c) 2017 Robert McNeel & Associates.
# See License.md in the root of this repository for details.
import scriptcontext
import clr
import sys
from Rhino.UI import *
from Eto.Forms import Form, Dialog, Label, TextBox, StackLayout, Orientation, Button, HorizontalAlignment, VerticalAlignment, TextAlignment, NumericUpDown, MessageBox, DropDown, CheckBox, TableLayout, StackLayoutItem, DynamicLayout, Control, Panel, Form
from Eto.Drawing import *
# Custom label helper to set alignment
def L(text):
    label = Label()
    label.Text = text
    label.VerticalAlignment = VerticalAlignment.Center
    label.TextAlignment = TextAlignment.Right
    return label
def CB(text):
    cb = CheckBox()
    cb.Text = text
    return cb
form = Dialog[bool]() # return True or False from ShowModal()
form.Title = "My Collapsible Eto Form"
form.Resizable = False
form.Padding = Padding(5)
# set content of the collapsed section
collapsePanel = DynamicLayout()
collapsePanel.Visible = False
collapsePanel.Padding = Padding(40, 10)
collapsePanel.DefaultSpacing = Size(5, 5)
collapsePanel.BeginVertical()
collapsePanel.AddRow(None, L("Density:"), NumericUpDown())
collapsePanel.AddRow(None, L("Maximum angle:"), NumericUpDown())
collapsePanel.AddRow(None, L("Maximum aspect ratio:"), NumericUpDown())
collapsePanel.AddRow(None, L("Minimum edge length:"), NumericUpDown())
collapsePanel.AddRow(None, L("Maximum edge length:"), NumericUpDown())
collapsePanel.AddRow(None, L("Maximum distance, edge to surface:"), NumericUpDown())
collapsePanel.AddRow(None, L("Minimum initial grid quads:"), NumericUpDown())
collapsePanel.EndVertical()
collapsePanel.AddRow(None, CB("Refine mesh"))
collapsePanel.AddRow(None, CB("Jagged seams"), CB("Pack textures"), None)
collapsePanel.AddRow(None, CB("Simple planes"))
# button to toggle collapsing
collapseButton = Button()
collapseButton.text = "v"
collapseButton.MinimumSize = Size.Empty
def collapseButton_Click(sender, e):
	try:
		if collapsePanel.Visible:
			form.ClientSize = Size(form.ClientSize.Width, form.ClientSize.Height - collapsePanel.Height)
			collapseButton.Text = "^"
		else:
			collapsePanel.Visible = True
			collapseButton.Text = "v"
			form.ClientSize = Size(max(form.ClientSize.Width, collapsePanel.Width), form.ClientSize.Height + collapsePanel.Height)
	except:
		print ("Unexpected error:", sys.exc_info()[0])
		pass # so we don't bring down rhino if there's a bug in the script
collapseButton.Click += collapseButton_Click
# a few buttons always shown at the bottom
previewButton = Button()
previewButton.Text = "Preview"
cancelButton = Button()
cancelButton.Text = "Cancel"
def cancelButton_Click (sender, e):
	try:
		form.Close(False)
	except:
cancelButton.Click += cancelButton_Click;
okButton = Button()
okButton.Text = "OK"
def okButton_Click (sender, e):
	try:
		form.Close(True)
	except:
okButton.Click += okButton_Click
# set default buttons when user presses enter or escape anywhere on the form
form.DefaultButton = okButton
form.AbortButton = cancelButton
toleranceUpDown = NumericUpDown()
# our main layout
layout = DynamicLayout()
layout.DefaultSpacing = Size(2,2)
layout.AddSeparateRow(None, L("Tolerance"), toleranceUpDown, L("millimeters"), collapseButton)
layout.AddCentered(collapsePanel) # we need this auto-sized so we can get its width to adjust form height
layout.Add(None); # expanding space, in case you want the form re-sizable
layout.AddSeparateRow(None, previewButton, cancelButton, okButton);
form.Content = layout;
if form.ShowModal():
	print ("Do something, user clicked OK")
Thank you for taking the time to go through that Scott. I just brought them into WinMerge and it looks like creating the objects without parameters is the current solution. I’ll try to run with that process.
As a side note, I just searched for “python eto forms” on YouTube. There were two hits… one from 4 years ago that is 1:14 long with no audio. The second is from 8 years ago, is 1:05 long and has no dialog. So it seems that Rhino is the only software using Eto with Python?
I have no idea how I am going to learn this. Where did everyone get their knowledge from?
Henry
We are actually working on new documentation as we speak. So I hope to get that out as soon as we can.
Here are some started guides:
yes, it’s unfortunate that that is not possible in Python 3. If you have to create many of the same controls, e.g. a series of numeric steppers, it helps to create a function for it, that will help keep your code more concise.
Mostly brute force honestly. But I think that was a bit painful, so as Scott says, I’m writing some docs to make jumping into Eto a lot easier.
All of the scripts are old, you need to make sure you use IronPython (2) for a chance of them working, or the syntax will be off.
Half works, the collapsing doesn’t seem to collapse correctly for me on Mac
If I add the below code, It works for me and I can collapse and uncollapse the form
collapsePanel.Visible = True # <-- Add this line
SampleEtoDialog.py
Works for me in IronPython 2, nothing exciting, but the barebones work
This works for me
Change the code in the OnCaptureButtonClick with this
    # Capture button click handler
    def OnCaptureButtonClick(self, sender, e):
        # Capture the active view to a System.Drawing.Bitmap
        view = scriptcontext.doc.Views.ActiveView
        bitmap = EtoExtensions.ToEto(view.CaptureToBitmap())
        self.m_image_view.Image = bitmap
        # Update the text label
        self.m_label.Text = 'Captured view: {}'.format(view.ActiveViewport.Name)
        # Disable the default button
        self.DefaultButton.Enabled = False
Works well for me
I hope this makes your journey into Eto a bit easier @Henry_Wede, what are you hoping to make with Eto? :slight_smile:
Sorry for the delayed response @CallumSykes , I’ve spent a difficult month convincing a robot to do what I want it to.
My first project with ETO was going to be creating and operating on some toolpaths. I have collected a lot of classes for this and would like to make them more “presentable”.
I am going put ETO on the far back burner until it becomes more friendly to use. I normally use PySide for Python applications and really like it. There are some pieces of information around on using tkinter with Rhino. Although tkinter looks straight out of the 1970s, it is a standard and well documented. Even though tkinter is not officially supported by McNeel, maybe I can get something working.
Cheers,
Henry
Congrats on besting the charisma of your local Robot.
I’ve just dropped some docs, these might help, they might not. If tkinter works better for you, I’d suggest you use it :slight_smile:
First, thank you for spending the time to put together a current set of documentation. It is the only Python + Eto in the known universe so you are pretty famous!
I decided to give it the old college try and go through the examples.
The color picker example does not work on my Rhino version 8 SR8. It doesn’t look like it returns the chosen color?
Traceback (most recent call last):
File “file:///C:/Users/henry/.rhinocode/stage/hgojy1jz.e2d”, line 4, in
NameError: name ‘Dialog’ is not defined
Where is the best place for me to post things like this?
I’d upgrade to the latest SR if you can, SR8 is pretty old. Everything was tested in SR15 or above.
I think a new thread is always good. But this may solve your issue and save you the trouble → Issue in Eto Docs python sample - #7 by CallumSykes
It’s also helpful to let me know which sample you ran so I can try it, and ideally push a fix to the docs.
