I was able to make a popup by drawing from one of the given sample forms, as shown by the code below. I was wondering how to make it so that the form is dockable? I have a draft of how it might be done commented right near the bottom of the code, but if that is correct, how would I go about finding a DockBarId?
Thank you so much in advance!
import System
import Rhino
import Rhino.UI
import Eto.Drawing as drawing
import Eto.Forms as forms
import scriptcontext as sc
# SampleEtoModelessForm class
class SampleEtoModelessForm(forms.Form):
# Initializer
def __init__(self):
self.m_selecting = False
# Basic form initialization
self.Initialize()
# Create the form's controls
self.CreateFormControls()
# Fill the form's listbox
self.FillListBox()
# Create Rhino event handlers
self.CreateEvents()
print("Done initilaizing")
def Initialize(self):
self.Title = 'Sample Modeless Form'
self.Padding = drawing.Padding(5)
self.Resizable = True
self.Maximizable = False
self.Minimizable = False
self.ShowInTaskbar = True
self.MinimumSize = drawing.Size(200, 150)
# FormClosed event handler
self.Closed += self.OnFormClosed
# Adds a listitem to the listbox
def AddObject(self, obj):
item = forms.ListItem()
item.Text = obj.ShortDescription(False)
if obj.Name:
item.Text += " - " + obj.Name
item.Tag = obj.Id
self.m_listbox.Items.Add(item)
# Fills the listbox with document objects
def FillListBox(self):
iter = Rhino.DocObjects.ObjectEnumeratorSettings()
iter.NormalObjects = True
iter.LockedObjects = False
iter.IncludeLights = True
iter.IncludeGrips = False
objects = sc.doc.Objects.GetObjectList(iter)
for obj in objects:
self.AddObject(obj)
# CloseDocument event handler
def OnCloseDocument(self, sender, e):
self.m_listbox.Items.Clear()
# NewDocument event handler
def OnNewDocument(self, sender, e):
self.FillListBox()
# EndOpenDocument event handler
def OnEndOpenDocument(self, sender, e):
self.FillListBox()
# OnAddRhinoObject event handler
def OnAddRhinoObject(self, sender, e):
self.AddObject(e.TheObject)
# OnDeleteRhinoObject event handler
def OnDeleteRhinoObject(self, sender, e):
for item in self.m_listbox.Items:
if item.Tag == e.ObjectId:
self.m_listbox.Items.Remove(item)
break
# OnSelectObjects event handler
def OnSelectObjects(self, sender, e):
if self.m_selecting == True:
return
if e.RhinoObjects.Length == 1:
i = 0
if item.Tag == e.RhinoObjects[0].Id:
self.m_listbox.SelectedIndex = i
break
else:
i += 1
else:
self.m_listbox.SelectedIndex = -1
# OnDeselectAllObjects event handler
def OnDeselectAllObjects(self, sender, e):
return
def CreateEvents(self):
Rhino.RhinoDoc.CloseDocument += self.OnCloseDocument
Rhino.RhinoDoc.NewDocument += self.OnNewDocument
Rhino.RhinoDoc.EndOpenDocument += self.OnEndOpenDocument
Rhino.RhinoDoc.AddRhinoObject += self.OnAddRhinoObject
Rhino.RhinoDoc.DeleteRhinoObject += self.OnDeleteRhinoObject
Rhino.RhinoDoc.SelectObjects += self.OnSelectObjects
Rhino.RhinoDoc.DeselectAllObjects += self.OnDeselectAllObjects
# Remove Rhino event handlers
def RemoveEvents(self):
Rhino.RhinoDoc.CloseDocument -= self.OnCloseDocument
Rhino.RhinoDoc.NewDocument -= self.OnNewDocument
Rhino.RhinoDoc.EndOpenDocument -= self.OnEndOpenDocument
Rhino.RhinoDoc.AddRhinoObject -= self.OnAddRhinoObject
Rhino.RhinoDoc.DeleteRhinoObject -= self.OnDeleteRhinoObject
Rhino.RhinoDoc.SelectObjects -= self.OnSelectObjects
Rhino.RhinoDoc.DeselectAllObjects -= self.OnDeselectAllObjects
# Create all of the controls used by the form
def CreateFormControls(self):
# Create table layout
layout = forms.TableLayout()
layout.Padding = drawing.Padding(10)
layout.Spacing = drawing.Size(5, 5)
# Add controls to layout
layout.Rows.Add(forms.Label(Text = 'Rhino Objects:'))
layout.Rows.Add(self.CreateListBoxRow())
layout.Rows.Add(self.CreateButtonRow())
# Set the content
self.Content = layout
# Listbox.SelectedIndexChanged event handler
def OnSelectedIndexChanged(self, sender, e):
index = self.m_listbox.SelectedIndex
if index >= 0:
self.m_selecting = True
item = self.m_listbox.Items[index]
Rhino.RhinoApp.RunScript("_SelNone", False)
Rhino.RhinoApp.RunScript("_SelId " + item.Tag.ToString() + " _Enter", False)
# Called by CreateFormControls to creates the
# table row that contains the listbox
def CreateListBoxRow(self):
# Create the listbox
self.m_listbox = forms.ListBox()
self.m_listbox.Size = drawing.Size(200, 100)
self.m_listbox.SelectedIndexChanged += self.OnSelectedIndexChanged
# Create the table row
table_row = forms.TableRow()
table_row.ScaleHeight = True
table_row.Cells.Add(self.m_listbox)
return table_row
# 'Select' button click handler
def OnSelectClick(self, sender, e):
Rhino.RhinoApp.RunScript("_SelAll", False)
# 'Clear' button click handler
def OnClearClick(self, sender, e):
# table row that contains the button controls.
def CreateButtonRow(self):
# Select button
select_button = forms.Button(Text = 'Select All')
select_button.Click += self.OnSelectClick
# Clear button
clear_button = forms.Button(Text = 'Clear')
clear_button.Click += self.OnClearClick
# Create layout
layout = forms.TableLayout(Spacing = drawing.Size(5, 5))
layout.Rows.Add(forms.TableRow(None, select_button, clear_button, None))
return layout
# Form Closed event handler
def OnFormClosed(self, sender, e):
# Remove the events added in the initializer
self.RemoveEvents()
# Dispose of the form and remove it from the sticky dictionary
if sc.sticky.has_key('sample_modeless_form'):
form = sc.sticky['sample_modeless_form']
if form:
form.Dispose()
form = None
sc.sticky.Remove('sample_modeless_form')
# TestSampleEtoModelessForm function
def TestSampleEtoModelessForm():
# See if the form is already visible
print("Testing if form is already visible")
return
print("It was not available, so the code is continuing. ")
# Create and show form
form = SampleEtoModelessForm()
#Rhino.UI.Panels.RegisterPanel(Rhino.UI.DockBarId.ObjectProperties, form, "MyDockableForm", System.Drawing.SystemIcons.Information.ToBitmap())
#Rhino.UI.Panels.ShowPanel(Rhino.UI.DockBarId.ObjectProperties)
form.Owner = Rhino.UI.RhinoEtoApp.MainWindow
form.Show()
# Add the form to the sticky dictionary so it
# survives when the main function ends.
sc.sticky['sample_modeless_form'] = form
if __name__ == '__main__':
