Problem with the energy plus simulation
Good noon everyone
My name is Vighnesh and i am working grasshopper and Galapagos/octopus to optimise energy parameters.
I am using energy plus simulation engine of climate studio to calculate the cooling loads. When i try to run Galapagos or octopus the value of the cooling load (OE in this case) doesn’t change at all without manual interruption to the components like roofs or walls (shown in sliders). But, the embodied energy works when it is connected to Galapagos or octopus using the same model.
Can anyone tell me if there is any problem with the structure.
I have uploaded the gh file and rhino file with this post.
1stiy.gh2.1.3dm
i am just wildly guessing that you could plug a toggle into the tog input in your output component.
Thanks sir, I will tried it out and still it did not work sir.
hi, pls dont double post, i found your exact same question from a month ago.
it seems you should take the advise given in that topic.
