Problem with determining point based on surface UV
I’m in the process of prototyping an algorithm to create a clipping/cutting volume based on the scene bounding box (inflated) and a set of clipping planes in the rhino document.
The basic idea is:
  • intersect planes with (inflated) box.
  • generated surfaces Surfaces from intersection curves.
  • split box with surfaces
  • cap the new breps Closed breps
  • generate checkpoints Points for Surfaces
  • keep Closed breps that contain Points
The problem is that for some intersection surfaces generation of Points yields some that don’t lie oriented around the middle of the surface as highlighted in the attached screenshot. How can I fix this?
edit: Note that rotating the selected clipping plane to some degree will result in proper point, and thus clipping volume, generation
uv_point_problem.gh (28.8 KB)
clippingvolume_gh.3dm (198.5 KB)
Thanks in advance for any useful information.
I’ve found a much better way to generate the check-points Points:
In case someone is wondering (and even if not), here is how it looks like:
