Problem is strange because it doesn’t occur every time.
When I bake geometry with assigned material as an attribute, created geometry instead of using already manually prepared earlier material, makes a new material with the same name.
I used three different plugins to test: Human, Elefront, Flexhopper
Everything is shown in the video.
Note, that if I delete created geometry, the material is also deleted.
The error lies with the plug-ins Elefront, Human and Flexhopper. I’m guessing they use ‘old-style’ material table access to figure out what material to use. Regular Grasshopper will bake just fine as it should. If a material already exists in the render material table it will use that. If a material doesn’t exist yet a new one will be created.
