frhn3d0
(Frhn3d0)
December 28, 2020, 3:25am
1
Any clues what’s going wrong here? I’m getting “invalid brep” from RevSrf, while trying to create a bowl/pot shape by:
making a (poly?)curve to define the outside profile, horizontal from the origin out for the bottom, curving up for the side
offsetting that outside profile curve to get an inside profile curve
flipping the inside curve, so its start is up at the rim where the outside profile ended and its end is back on the z-axis
connecting the two, making one (poly?)curve of the two, with a little segment across the offset at the rim
revolving that result around the z-axis
Some similar attempts work (produce valid surfaces), but I haven’t figured out a pattern to which do and which don’t yet.
pot.gh (6.8 KB)
This produces a closed brep
And so does this. It was probably the flip going into the connect curves which was the problem
frhn3d0
(Frhn3d0)
December 28, 2020, 12:31pm
4
Thank you.
Any hints to help me understand what’s wrong with using the flip?
frhn3d0
(Frhn3d0)
5
Thanks! That’s tidy, and teaches me something.
The mystery to me is why a data tree goes into Brep Edges with two branches but comes out with only one branch?
If the input to RevSrf is flattened, the data tree going into Brep Edges has one branch with two items and comes out with two branches, as expected. That requires the input to Loft to be flattened, again as expected.
“Ours is not to reason why…” but to just deal with it.
