Problem offsetting a curve surface
What i intended to do is to offset this frame to have a degree of thickness, however the curve jus explodes
OFFSET PROBLEM.gh (14.7 KB)
Just fyi,
OFFSET PROBLEM.gh (13.2 KB)
try using this component offset curve on surface
Quad panels component requires a plug-in. Please internalize geometry in the surface container.
Well, yeah. You are trying to offset the curves when what you want to do is offset the surfaces.
