Since I use Rhino 5 I can’t use the blend command the way i did it in Rhino 4 without problems. I split a surface, move one part of it and make a blend between these two parts. The blend and the 2 surfaceparts won’t join at all. The only way for me to fix is to join 2 naked edges, but that causes bad problems if my customer loads the data into his solidmodeler. i tried kurvenetworks, and it works fine, but takes way longer, so i would prefer to get the blend work again. here is a file! Thanks Henningblend problem.3dm(98.4 KB)
Hi Henning,
Could it be you made the blend in another file than this?
It appears to me that the blend is created in a file with a much higher file tolerance.
I created a new blend in the file and it joined just fine : blend problem_WD.3dm(105.9 KB)
Can you try and make the blend in the file you attached, to see if it is your system or the original file that
is causing the loose fit.
-Willem
Hello Willem,
thanks for the quick reply! I just checked, but no, I made the blend in exactly this file. I made a complete new file with a new simple surface to recheck now, and it does not join again. Seems to me that its the system. just reinstall rhino, or are there any other things to try to fix the system thanks henning new file.3dm(76.4 KB)
Hi Henning,
No need to reinstall (just now)!
What version are you running? Go to Help -> Check for Updates…
hit the text check now to find if you have the latest version.
What baffles me is that in he same file I cannot get the result you get:
new file.3dm(106.2 KB)
Mine has denser isocurves and matches the 2 edges better.
Can you walk me through the steps you take to create the blend?
What I do is this:
1: BlendSrf command
2: Select both edges
3: Set continuity to Curvature and add slashes at the extends of the corner fillets.
4: Hit enter.
-Willem
Hello Willem,
yes it’s the latest version! i did everything you did, but i have chosen tangency. i now tried curvature but had no luck too. any other idea? thnks henning
I used tangency as well, I mistyped that.
I think @Pascal or someone else from McMeel has to chime in to see why you are getting a different result in this file than me, when we apparently use the same file, settings and procedure. I’m at a loss as to how I can help you further.
-Willem
–004_CA032E15ED512A42A8D0D498070679C9429F298F4AECCR10PUBLICe
Content-Type: multipart/alternative;
boundary=“000_CA032E15ED512A42A8D0D498070679C9429F298F4AECCR10PUBLICe”
–000_CA032E15ED512A42A8D0D498070679C9429F298F4AECCR10PUBLICe
Content-Type: text/plain; charset="utf-8"
Content-Transfer-Encoding: base64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Content-Type: text/html; charset="utf-8"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–000_CA032E15ED512A42A8D0D498070679C9429F298F4AECCR10PUBLICe–
Content-Type: image/jpeg; name="image001.jpg"
Content-Description: image001.jpg
Content-Disposition: inline; filename=“image001.jpg”; size=359;
creation-date=“Wed, 11 Sep 2013 16:54:27 GMT”;
modification-date="Wed, 11 Sep 2013 16:54:27 GMT"
Content-ID: image001.jpg@01CEAF20.55DBB740
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAoHBwkHBgoJCAkLCwoMDxkQDw4ODx4WFxIZJCAmJSMg
IyIoLTkwKCo2KyIjMkQyNjs9QEBAJjBGS0U+Sjk/QD3/wAALCAAtAC0BAREA/8QAHwAAAQUBAQEB
AQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1Fh
ByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZ
WmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXG
x8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/9oACAEBAAA/APZqKKKKKKKKKKKKKKKK
KKKKKKKKKKKKKKKKKKK//9k=
–004_CA032E15ED512A42A8D0D498070679C9429F298F4AECCR10PUBLICe–
This looks like a bug to me at the moment. It looks to me like Henning, you added shapes at the quadrants- if I do that, I also get a significant, 10x tolerance, gap between the edges. Digging more.
Thanks Pascal,
Exactly, was at the quads! Henning
Send from my hinkelsteindesktop!
