Hello
I have problems with the installation Rhino 7 for Windows.
Installation failed with error code NetEx48Redist: - 2146885628
how can i fix this?
Hello
how can i fix this?
Hi -
Please post the file name of the exe that you are trying to run.
Thanks.
Is your Windows OS fully updated to the latest version?
You can manually download and install the .NET Framework 4.8 from this site:
Download .NET Framework 4.8 | Free official downloads (microsoft.com)
when installing NET Framework the same error. File not found
Hi -
Did you make sure that Windows is completely updated?
I’m afraid that not being able to install the NET Framework is an indication of a bigger problem than just not being able to install Rhino.
hi,
I could not run the update rhino 7.12 on my laptop… i installed NET Framework 4.8, stopped antivir but there is allways the note : download failed. on my desktop computer the update was successful.
please could you give me a hint how to fix that? thanx
Hi -
Does that mean that Rhino 7 is installed and you are having problems installing the 7.12 update?
Can you provide the exact error message?
yes rhino 7 SR 11 is installed.
sorry the error mesage is in german, but it says download failed, check your internet connection.
should I send you the log file?
Hi -
How are you updating Rhino to SR 12? Do you have updates enabled on the Rhino Options > Updates and Statistics page or are you manually downloading the program, and, if so, from which link?
