Problem in CENTR POİNT
Hi, I am a new user , want to create a point center , used Area Centroid , But there is a difference , Is there a suitable solution? thanks
Hello - the Gumball is located at the center of the object(s) bounding box, not the object center.
Thank you for quick response, is there a quick way to create a point the center of the object . Thanks
What’s wrong with AreaCentroid?
Hello - I’m not sure I follow but, AreaCentroid will get more of a geometrical center of the object - if you want the bounding box center, i.e. what matches the default Gumaball center, then there is not a clean way to get that in one step in plain Rhino - I’ll make a quick script.
BBCen.py (307 Bytes)
use a macro like this to run it off of a button or alias:
! _-RunPythonScript "Full path to py file inside double-quotes"
Thanks .
Adding a “center point” option to the BoundingBox command should be considered as a future enhancement,
