I was just testing this great GH plugin when I saw in the probe component
pressure (m^2/s^2) and pressure coefficient (no unit )
Could somebody tell me what kind of pressure is that and what is a pressure coefficient ?
Maybe cp values ? - ratio between pressure in stationary/pressure on surface
A pressure is a force/m^2 - N/m^2 so I am a bit confused
gerry
Moved to Grasshopper category
Hi, gerry.
I was confused by the same thing. m^2/s^2 is the SI unit of Pk (kinematic pressure).
Found that info on the link below:
https://www.openfoam.com/documentation/guides/latest/doc/guide-applications-solvers-variable-transform-kinematic-pressure.html
How I converted it to newtons:
Just multiply your results with air density.
Hope this helps,
Stefan
thanks, you saved me
gerry
