Hello people,
recently I encountred a problem with “Trim with Brep”. So If you try to trim some curves, which are not cut by the Brep, then you get some bad results. Furthermore every calculation generates a different result. Try to put a relay in between…
Am I using the comp wrong or what is the problem here?
Rhino Version 7 (7.3.21039.11201, 02/08/2021)
potential_bug_trim_with_brep.gh (13.6 KB)
