Hi there!
Quick question: is it possible to pop up any other toolbar other than the “popup toolbar” or even better asign mutliple popup toolbars to different keyboard shortcuts?
thanks konrad
Hi there!
thanks konrad
Tip: Create Aliases, example: Alias:xCP Command: '_ShowToolbar “Cplanes”
nice- but it isn’t quite the same as the popup interaction. i would like to press a keyborad shortcut (or alias) and have the toolbar open under the mouse cursor and disappear after a single commant use.
Use the following syntax to have a toolbar popup:
_PopupToolbar "ToolbarName"
–Mitch
Yes! thanks.
Sorry
, as Alias works but bad tip, better an faster if your define keyboard shortcuts, this run’s PopupToolbar command directly, self-contained from command console.
better late than never: many thanks!
