My colleague who works in AutoCAD is exporting these models as polysurface, however when I open these files in Rhino, I can only see the curves as a wireframe.
Furthermore, the curves are very stubborn. For example, I want to extract the face curves of one of the cogs. But I can’t join those curves together. I can’t project the curves to the C plane. Curveboolean fails in weird ways…
Anyone has an idea where the error originates ? Is it the export settings in AutoCAD or the import settings in Rhino ?
I see it now, same problem here. I cannot answer your question about the reason. But it is possible to extract a closed curve by selecting all curves, extrude into surface and intersect with a planar surface.
Hi @simon9
SolidWorks also sees nothing but curves in the file, so I’m guessing it’s an export issue - hopefully your colleague or someone here with AutoCAD experience can help you out.
-Jakob
