Hi Guys
Im trying to create a polyline from multiple points , what am i doing wrong ?
also , is there a way i can create surface from this points without making line/edge first? (like the surafce from 4 points tool )
thank you
Hi Guys
thank you
Try to “Flatten” the vertices input of Polyline.
Please, use Merge
component instead of feeding that giant spaghetti set in one input.
This is much easier to edit and you would have seen the problem right away - the output of Merge would have been a tree and not a list.
As for the surface, I don’t think you can create it from the points only, use Boundary Surfaces
after your Polyline.
