I’m wandering of someone can help me to know how to array the polygon on the object as I try to array, project and flow along surface, but it doesn’t work for me .Polygon.3dm (312.6 KB)
I believe it is simply impossible to create a sphere with equal shaped polygons. Do a search on “Geodesic construction” on the internet to see what is or isn’t possible.
In any case it will have to be constructed from the ground up, once you know the components involved.
This is true. Most experts call these solids geodesic grids. Grids made of hexagons and pentagons are called Goldberg polyhedra. The easiest way to make them is to use Rhino plugin called RhinoPolyhedra. You can download this plugin from this page: RhinoPolyhedra | Food4Rhino
After the download and installation, run the plugin by typing the word Polyhedron in the command prompt. The plugin calls Goldberg polyhedra “Dual Geodesic Icosahedra.” Examples of Goldberg polyhedra:
