Points -> Closed curves
I want to make the points in surface into several closed curves like above pictures.
What should I do?
Even if it’s new, it’s fine.
Thanks in advance!
Hi and welcome to the forum!
You can connect a polyline component with in-between a “Flip matrix” component if you want U or V direction.
2020-03-30 22_20_33-Window
Or, if you want to extract directly the lines, use “Iso Curve”:
isocurves.gh (5.4 KB)
Thank you for reply :slightly_smiling_face: :grinning:
