Point plane intersection for Kangaroo on plane goal
Hi there,
I want to inflate mesh while keeping the naked vertexes on their initial curve plane.
I will use On Plane Kangaroo goal component, and for that i need the points order in different branches.
I am looking for a way to find the intersection event between points and planes in order to sort them.
I will appreciate a solution or every other idea for this problem.
(Weaver bird is required for the definition)
thanks a lot,
Noam
point plane intersection.gh (11.2 KB)
I don’t know why you are going to use OnPlane goal… and what’s the difference by just using Anchor orAnchorXYZinstead, anyway have a look at the attachment.
point plane intersection_re.gh (16.5 KB)
thank you for your answer.
apparently I didn’t explain myself well.
I am trying to create a catenary structure while keeping the naked points planar and parallel to z plane.
as you can see in the “top” attached picture the final mesh obviously do not stay inside the initial triangular region.
Like this?
point plane intersection_reV2.gh (18.2 KB)
Oh YES!
thank you so much.
I have failed to do it for so long.
